Help me connect this solinoid to my system NX related
So I have been running all Dynotune and had a chance to buy a New NX system for next to nothing. Needless to say all I wanted were the solonoids from the kit since they were about 3 times the size of my Dynotune kit. The fuel noid was straight forward but the N2O noid is being a bit of a challenge. If you look at the pictures you can see that my purge and N20 noids are daisy chained with a 4an swivel fitting. Well looking at my new noid I find that "IN" on rgw NX noid is what I assume a 6an fitting???I guess I have 2 options here. One is to find a male 4an to male 6an fitting or ditch the fittingings and relocate the new solinoid to the top of the motor next to the TB and use a male 4an to male 6an 18" line. I like that idea because it will match up the location of the fuel noid and look cool. I guess my big question is: On the IN fuel side is that indeed 6an???
Inlet size
It looks the the inlet size is for the manifold for the pressure switch in the Gemini 2 Kit. I believe you can get the right AN fitting for your setup. The directions are at my shop, and I don't know if they have what size it is in the directions. Hope this helps.
LS1TECH Sponsor
The soleniod inlet hole iS 1/4NPT. you can get 1/4NPT x -3AN, -4AN, or -6AN. It depends on the size of your feed line. most single nozzle/plate kits come with a -4AN feed line.
Nevermind brother. I went to your website and seen it show for the fitting and called it a (filter) fitting. I happened to have a filter here with adapters on it that I was not using. I pulled one off and BAM I am good to go. Thanks
Grant thats great to hear. Do you guys actually carry them? Could I get a line custom made for this? If no line how about a link to the fitting so I can order up. I have a 4AN setup.
LS1TECH Sponsor
Hoses. We can make any custom length that you need. However i cannot make a line with an NPT fitting pressed on. Will be a female AN that you would connect to the fitting listed above.
Let me know if you have any other questions/concerns.
