Whats the catch
Whats the catch
I was changing my spark plugs today when i got to the passenger side bank i noticed i couldn't get my hand down there. Is there a secret to changing the passenger side bank spark plugs.
Remove the coil packs and leave the back bolt out of the bracket when you are done so you don't have to worry about it the next time. It's pretty easy this way because it opens up enough room to get a ratchet with a swivel down there.
Removing the AIR helps a ton, unbolting pass side coil pack helps a little, I go up from the bottom for #8. And I ground down all of the sadistic spikes on the coil packs because those things can be brutal anytime you are working in there.
