Notices
WTB 60# injectors
Old 03-17-2009, 04:34 PM
2000 yenko's Avatar
Default WTB 60# injectors
i am putting a turbo set up on my camaro and i am looking for 60# injectors.
Old 03-17-2009, 09:23 PM
11 Second Truck Club
sprayinLS1s's Avatar
i was going to do the same thing, but decided to stay with the bottle, these are new in the box, and came from thunder racing, below is the info on them..... pm me an offer
135-INJ-LU107FM-8 Siemens/Mototron Deka 4 Flow-Matched 63# Style Fuel Injectors w/ USCAR Connection (Set of 8)
-Static flow @ 63lb/hr @ 43.5PSI = 630cc/hr (sold as 60 or 65lb/hr by some vendors)
-Static Flow Rate: 72.7 lb/hr @ 58.0 PSI (400kPa) = 762cc/hr
-Dynamic Flow Rate: 7.90 grams/second (300kPa)
-Coil Resistance: 12 Ohms / High Impedance / High-Z (No ECM driver modifications required)
-Gain: 0.11ms/mg, Offset: 0.055ms, Turn on time: 1.14ms @ 14VDC, Turn off time: 0.85ms @ 600KPa
-Dynamically flowed and grouped to within 1% tolerance using Racetronix custom injector flow bench
$440.00 Buy Wish
