Sage282
03-17-2009, 08:32 PM
So a few months ago I was driving to school slowing down at a stop sign when I heard a 'clunk' almost as if I had run over something and my car died. Long story short, I can rotate the engine probably 80 degrees each way by hand before it stops (turns over super easy by hand) I unbolted all the rockers and everything looks fine, all the valves are there, push rods, all the spark plugs look fine. I pulled the timing cover off as well and the timing chain still looks great and still has the normal 'slack' in it when the motor stops turning over which leads me to think it's a some sort of a tranny/converter issue...
My car is a 98' Z28, MS3 full bolt-on car with a YankSS3600 stall, the whole combo has about 12k miles on it since a fresh rebuild but I have no idea what kind of shape the tranny was/is in. I was just wondering if anyone has any ideas on what would be causing this on the trans/converter/flywheel side of things. Has anyone pulled the trans without being able to unbolt the converter? The way things sit right now (not being able to rotate the motor more than 80 degrees each way) it's going to be impossible for me to get them all out. I want my car running again! lol
