first nitrous install, need pics
i am installing a 90mm plate system from nitrous outlet, bottle in the spare wheel storage,
i am a complete nitrous noob, never install i nitrous kit before, and up here where i live there isn't much help to get, and only 1 other car with a nitrous kit,
can anyone post some pictures that i can look at and try to install my system like that?
i would be very thankfull for that, i've asked a few times about this, but never got any pics, so i havn't started to install it, dont wanna mess anything up
thanks!
thule.. iceland
thanks!
thule.. iceland
well for starters mount your plate, then find a good place you would like to mount ur solenoids you can mount them where ever you would like just make sure the lines can reach from the plate to the noids..........then run ur fuel line off of ur shrader valve on the fuel rail and hook that to ur nitrous solenoid...then run ur long line to the bottle and to the blue nitrous solenoid....once u get there post back or if you want pm me
thanks man, i will do that
one thing i've bin thinking about, someone told me i would have to remove my fuel pressure gauge? i have FAST fuel reals,
where would be the best place to mount the solenoids, i want to try to make it look as good as i can, i've bin trying to get the engine bay nice looking,
where is best to get the oine through the firewall, the hole underneath the ECU? or is a better place?
dosn't anyone have some pics for me? because of my english skills the instruction manual is no good,
how do i mount the solenoids? there arent any brackets with the kit, is it better to run the nitrous hose under the car, or in the car?
in the instruction manual, it says that i can take fuel from a test port, there is a hose besides the hose that connects to the fuel rail, there is some valve there, can i use that?
thanks for the answers, they came to an good use,
the search did not find enough pics
nice finger
the manual says that those are for the switch, but i will use them for the noids then.
can i take the nitrous hose thorugh the hole under the ECU, or is it best to make a new one?
i think i will do that aswell,
one thing i am thinking about,
does the heat from the headers not affect the nitrous? i've seen quite a few set ups where the nitrous filter is realy close to te headers,
where is best to mount the filter?
will the nitrous plate not affect the engine powerwise when i am not using it? do to the diffirent in length from the TB to the manifold?
where is best to mount the pressure valve?
where is best to mount the window switch?
and all the idiot questions, i've sent nitro dave a mail asking for some pics, but have not got an answer,
big thanks for the answers and pics!
thats the problem tuning cars up here, i have no cars to look at and do mine the same, my car will be the second lsx car to get nitrous, and the other one has NX direct port, so that dosn't realy help
