this glue an'it holding worth a dam
I'm attemping to glue a small tear in the TA front bumper right at the flange
where it bolts to the fender.
did these folks at the paint supply place sell me the wronge glue ?
I'm really surprized in how crappie it worked.
the images are'nt that great but you can get an idea of the repair.
image of glue here
http://www.geocities.com/stevethebody3/materials.htm
the stuff on the right
Thanks
image of glue here
Thanks
You will have to add material on the inside for the glue to hold that back together, or vee it out and then shape it back after the glue dries. I usually take another crap bumper and cut off some strips to back the repair with or fiberglass cloth will work in that glue as well helps to add strength otherwise it will just keep busting out like that. I have even pop riveted pieces to the bumper fixing cracks and tears and after it all dried then take out the rivets and fill in the holes you made. Hope this helps you out a little good luck with the repair it can be a pain
glue
?1. so this is the correct glue? they had 2 types of this stuff flexable and rigid
the girl did'nt know so I picked the rigid.
the right side has a much smaller tear seams to be holding there.
I let this glue dry for a couple hours in the sun seamed stronge untill I put just a tiny preasure pulling back?
I'm trying to glue the metal flange to the hard plastic inside bumper glue seams to be stuck good to the plastic but not the metal flange I would preferr not to drill the rivots and remove this metal flange any thought?
Thanks
Thanks
epoxy
image of glue here
Thanks
Thanks
epoxy
Hey man sorry about being nasty the other day it just seamed like alot of stuff was'nt working right stuff breaking just going though a bunch of crap lately not here but in life.
sorry man and thanks for the tips.
I can't seam to get a good image of this epoxy first time it came loose even though it appeared to be stronge was maybe 1/8" thick
maybe I should cake it on?
its cool, if that doesn't work use some material (woven material) over it kinda like the stuff you use for fiberglass, dremeling it would probably work good too. And yeah i know how it is breaking stuff seems like i've been getting better at breaking exspensive **** in the last two years.lolol
still not sticking
I don't see a way to add strips of additional material since it's in a corner.
I'm really dissappointed in the man that repaired this bumper I paid him real good money to fix and he did a shitty job maybe I'll have to talk to him about a redo not to optimistic though about him.
looks like I'll be forced to purchase another bumper an completely repaint hope it matches the hood & fenders.
Thanks for the tip on the repair.
