turbo fittings
Old 03-20-2009, 07:32 AM
dreamls1's Avatar
Default turbo fittings
anyone know what size fittings hook up the the feed and drain on a Turbonetics TC76? I am ordering all my fittings.
Old 03-20-2009, 08:52 AM
dreamls1's Avatar
anyone??
Old 02-12-2010, 08:51 AM
cjmatt's Avatar
bump, i need to know too
Old 02-12-2010, 12:18 PM
75tonyA's Avatar
The feed is usually 1/8 in NPT you can get that at ace hardware in brass. The drain is usually a flange that bolts to the turbo, you could make one out of aluminum and thread it with whatever you need. Or buy one that has an AN fitting machined in to clear tight areas.
Old 02-12-2010, 12:30 PM
BoOsT-CrAzY09's Avatar
either 1/8 npt or -6 theres adapters all over the internet for anything you would need most turbo feeds n drains are the same thread
Old 02-12-2010, 10:29 PM
ZL1Killa's Avatar
uh...turbonetics gives out drawings for the design they have...they are 1/8 NPT
Quick Reply: turbo fittings
