Window switch question
Old 10-20-2003, 06:25 PM
Birdy's Avatar
Default Window switch question
This has probably beat into the ground...But. I need to know what color the tach wire is? I am wiring in a MSD window switch. Would it be better to find the wire in the ECM bundle or is there a better place to access it? Thanks in advance for your help.
Robert
Old 10-20-2003, 11:05 PM
JF WS6's Avatar
Default Re: Window switch question
Check out the Harlan shift light install from install university.com. Should have all the info you need.
