are comp PRC springs a good spring to go with?
Old 03-20-2009, 12:49 PM
nobird8991's Avatar
Default are comp PRC springs a good spring to go with?
i'm looking to go with texas speeds torquer v.3 cam kit with 231/234 .643"/.598" 111 LSA and it comes with the comp PRC springs and i'm wondering if they are a good spring or if i should stay away from them. or if this is even a good deal?
http://texas-speed.com/shop/item.asp...d=175&catid=44
kit comes with Your Choice of Camshaft, Comp PRC Spring Kit, and Hardened Chromoly Pushrods for 689.99
is this a good deal or not the greatest?
Old 03-20-2009, 02:26 PM
TVWilkes's Avatar
The PRC spring will work perfect with your cam choice.
Old 03-20-2009, 03:12 PM
Eskimo's Avatar
There have been 2 instances in our local area of those springs taking a "set", losing height and spring pressure. There was another guy who had similar issues, he has a thread in the dyno section.
I'd look to PAC or PSI springs, personally.
Old 03-20-2009, 04:16 PM
vettenuts's Avatar
I agree. I have read of similar findings after a few thousand miles.
Old 03-21-2009, 09:39 AM
TVWilkes's Avatar
After 6 years and over 1 million sold there is nothing wrong with the PRC spring.
Old 03-21-2009, 10:13 AM
Old SStroker's Avatar
...and Big Macs are good for your heart.
Old 03-21-2009, 05:58 PM
racer7088's Avatar
Arrow
I am not on anyone's side but all springs will lose a little amount of pressure when first run.
If you float a valve a lot you can lose a lot of spring pressure fast as well.
I have seen 1000.00+ springs lose some serious pressure in just a few dyno pulls a few times with craziness going on!
You just have to know everything about the application to know what went wrong if anything is all I am saying.
racer7088's Avatar
Thumbs up
That's what I am hoping!
Old 03-21-2009, 09:27 PM
Randy WS6's Avatar
I run them with my .651 lift, Grate springs .never had any problems with them, But i change them out about ever 20,000 miles. But with your lift you can probably go longer,like 25 to 30,000 miles. It all how high you rev them.
Old 03-21-2009, 10:06 PM
SweetS10V8's Avatar
Old 03-22-2009, 10:42 PM
2000PewterZ28's Avatar
The PRC springs will work just fine with that cam. There has been many post with people running these springs in excess of 25,000 miles.
Old 03-22-2009, 11:17 PM
405HP_Z06's Avatar
Agree^^^^
Pac 1518 or PSI 1511ML
