Drag Racing Tech
Which gears for my car and the 1/4 mile???
Old 03-21-2009, 08:59 AM
TexasVortexx's Avatar
Question Which gears for my car and the 1/4 mile???
Hey guys I am currently completing the build of my car. I currently have a fab 9 rear with 4.30 gears and running on 28 inch slicks and drag radials, M6 with suspension. The new motor is a Raymac 408 built for about 700 hp engine dyno and have a direct port NX system which I will shoot another 200 to 300hp for track passes. My concern has been I may run out of gear with the current 4.30 gears. I am scheduled to put my new spool in with 4.10's. Rev limiter will be set at 7200 rpm.
Can I make the full 1/4 mile with 4.30's without running out of gear or should I drop down to 4.10's???
TIA
Jay
Old 03-21-2009, 09:03 AM
87Lt1Monte's Avatar
i would drop down in gear myself..
Old 03-24-2009, 07:16 PM
Thanks, anyone else
Old 03-25-2009, 10:47 PM
LS1Tech Premium Sponsor
ssvert99's Avatar
Richmond Gear has a good calculator on their website. use your existing numbers and figure in the mods. chances are you may even need a 3.89.
Old 03-25-2009, 11:08 PM
Thanks Steve
Old 04-01-2009, 10:22 PM
Gotta be someone here with a similar setup as mine?????
