Need help, been ignoring an issue
Old 03-21-2009, 09:12 AM
whiteboycntdnce's Avatar
Default Need help, been ignoring an issue
I bought a set of Weld Pro Stars, 15X10 w/ 7.5" backspacing for the rear, and another set of Pro Star 15X4 w/ 1 7/8" backspacing for the front. I've had 2 different people try to grind the front calipers down and tell me those wheels will NOT work (for the front)
But I got those numbers off this forum... Does anyone know for sure, if those 15X4's will fit up front? I know there is a large amount of grinding needed, and neither of these guys are F-body people... So maybe they just arent aware of how much needs to come off... but before I start the process of sending these wheels back to JEGS, I'd like to find some sort of definite answer
Thanks!
Old 03-21-2009, 10:29 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You really need a 15x4 with 2.25" BS
Old 03-21-2009, 12:12 PM
RENE'S RAGE's Avatar
What about a 5/16" wheel spacer.
Old 03-21-2009, 01:16 PM
I bought the wheels off JEGS and the only 15x4 they offered with our bolt pattern was the 1 7/8" backspacing... i could use a spacer if it would help, because I did buy all new ARP wheel studs
