Oil drain plug location?
Old 03-21-2009, 01:28 PM
Lopoetve's Avatar
Default Oil drain plug location?
Where the heck is the oil drain plug? I'm not seeing anything that resembles an oil pan at all like I'm used to...
I've googled like mad, but only 2 guides even have pics, and they look nothing like the bottom of my car :p
I see a bolt on each side of a flat thing on the bottom of the engine that might be it, but what's with the 2 bolts?
Old 03-21-2009, 01:37 PM
Greekey's Avatar
Its right in front of the oil filter. Pm sent.
Old 03-21-2009, 04:24 PM
Z28LS1camaroguy's Avatar
you prolly shouldnt be changing oil if you dont know where the oil drain plug is.
Old 03-23-2009, 03:02 AM
baldwintpenguin's Avatar
wow way to be a douche. you learn by diggin in, not staying away because you dont know everything about everything
obviously you were born knowing everything there is to know ever
Old 03-23-2009, 09:12 AM
vjo90rs8's Avatar
If you are used to old school engines then you are probably looking for a big steel black oil pan, but our cars have a nice aluminum one which is probably throwing you off. But basically it is the bolt in from of the oil filter that doesn't have any structural purpose.
Old 03-23-2009, 10:55 PM
samson_420's Avatar
Take your car to the proffesionals @ Shlep Boys. . . . . .
Oil drain plug, WTF is next? What does the oil filter look like. . . . . ****.
Old 03-23-2009, 11:23 PM
jsteele90's Avatar
how do i get underneath my car to change the oil?
Old 03-23-2009, 11:44 PM
GXPPOWER's Avatar
You probably should leave with a **** mentality like that. Your what gives everyone else a bad name. I'm sure you didn't always know how to work on a car now did you?
Old 03-23-2009, 11:47 PM
GXPPOWER's Avatar
and you can leave your car at the Used car lot. I could bring up stuff that you wouldn't know. want me to make you look like a inept moron?
Old 03-23-2009, 11:48 PM
GXPPOWER's Avatar
The same way you had someone else tune your car. its not hard to use tuning software. do you struggle using Notepad also?
Old 03-24-2009, 12:59 AM
No GXPPOWER its ******** like you who dont have a sense of humor that give "us" a bad name.
Old 03-24-2009, 01:33 AM
jsteele90's Avatar
not as hard as you struggle to find humor
Old 03-24-2009, 01:43 AM
tripps's Avatar
Damn, looks to be alot of hate goin on.
OP the bolt is facing the driver side door, just crawl under and look with a flashlight, its very noticeable.
Old 03-24-2009, 02:46 PM
samson_420's Avatar
^ He is lying there is no drain plug.
You have to drill a 1/2" hole right at the bottom of the oil pan(the big metal thing at the bottom of the motor).
Really, man. . . Open a ******* service manual and read.
Old 03-24-2009, 04:47 PM
tording99Z28's Avatar
Wait, you mean I have to get under the car to change the oil? Well F*** that!!!!!
Old 03-24-2009, 09:30 PM
ghardester's Avatar
It's the one on the drivers side of the rectangular thing that is under the car where the oil pan should be. Righty tighty, lefty loosy.
And don't feel bad for the crap the other posters have given. If it leaks too much, you just pour oil in and never have to change it because it's always fresh.
Old 03-24-2009, 10:09 PM
ThoR294's Avatar
this thread delivers.
pretty much look for the lowest bolt to the front of the car (where the engine is) that has oil around it
Old 03-26-2009, 02:23 AM
MurderedOut's Avatar
there is none, you have to suck it out with a turkey baster.
Old 03-26-2009, 09:10 AM
xbcrguy182x's Avatar
Hahaha, this is too much. I remember the first time I ever changed the oil. I made a mess. Oh and I tried taking out the oil filter with my hand. Good times...
Look for the bolt, you can't miss it. Driver's side. The oil filter is right up there as well. Just look up. When changing the filter, just remember to put some oil in the filter and rub some oil on the rubber seal and hand tighten it.
Old 03-26-2009, 10:57 AM
samson_420's Avatar
When you do find it, use a 1" impact on full torque to tighten it up.
Quick Reply: Oil drain plug location?
