Are these the same part?
Old 03-21-2009, 03:05 PM
JeaneGrae's Avatar
Default Are these the same part?
I am ordering a new engine but i am told i need to reuse my stock balancer/damper. Is the SLP underdrive pully a balnace/damper as well or are these two totally different parts? What is best for a gm ls6 crate engine?
Old 03-21-2009, 03:09 PM
fatdave's Avatar
on the ls motor it is all one piece.
Old 03-21-2009, 04:31 PM
DaveX's Avatar
The LS is internally balanced so it's just a damper/pulley.
Old 03-21-2009, 04:43 PM
01ssreda4's Avatar
i agree....and yes its the same thing, youre fine.
Old 03-21-2009, 11:29 PM
JeaneGrae's Avatar
So i would be ok going with the slp, powerbond or asp instead of my old stock pulley?
Old 03-22-2009, 09:21 AM
DaveX's Avatar
Absolutely. I would get an underdrive pulley. Make sure you get a new bolt, and it's best to use an install tool when you go to install it to keep from damaging the threads in the crank.
Old 03-22-2009, 01:23 PM
JeaneGrae's Avatar
Default Install tool
Thanks for the info. I've found the pulley, but did a search and can't find the install tool. who sells them?
Old 03-22-2009, 02:05 PM
01ssreda4's Avatar
buy 618hawks tool off of here. its a very nice piece.
