Turbo350 in a 67 camaro LS1
Old 03-21-2009, 03:32 PM
67lsrs's Avatar
Default Turbo350 in a 67 camaro LS1
Swapping an LS1 into my 67 camaro with a turbo 350 trans.
Ok I used the search and found most of the answers as far as flexplates adapters etc.. The one thing Iam having a hard time finding is what the VSS is actually needed for. Is this just for the speedometer or does the PCM use this for something else. In other words if I use a mechanical speedo do I need to worry about not having the VSS on the turbo350?
Thanks in advance
Old 03-21-2009, 06:19 PM
FLT
FLT's Avatar
The VSS will be needed if you are using a computer to control the transmission.
Old 03-22-2009, 12:51 PM
67lsrs's Avatar
So being a turbo350 is an older non-computer controlled trans then I do not need the vSS correct ?
Old 03-22-2009, 04:49 PM
WE TODD DID's Avatar
You do not need a vss if you are using a mechanical speedo.
Old 03-22-2009, 10:46 PM
67lsrs's Avatar
good deal thanks for the replys I appreciate it
