cam sensor problem?
cam sensor problem?
2001 trans am ls1 motor in 1968 firebird. I stroked the engine to 383, from the very first start I' ve had a cam sensor problem? Replaced sensor, sensor plug, checked wiring to computer. The car runs good for about 3-4 minutes at cold start up, then won't run past about 2400rpm after that. my tuner recorded a 20 minute ride. It showed a spike(no signal) from cam sensor. He says it might be the computer. any ideas? Thanks
I had a cam from cam motion the ring on the cam was cut wrong it would run ok ,then no start , then run ok ,the timing would be 180 out 1/2 the time , drove me crazy swap cam ran great jim
