A Stupid Motor Mount ? i Need Help With
Old 03-21-2009, 08:46 PM
Transamdrgracer04's Avatar
Default A Stupid Motor Mount ? i Need Help With
Trying to get the block done and i am having trouble with the left hand side motor mount that bolts to the block it does not line up at all. Does anyone have a picture of theres bolted on. I have not problem with the right side just need the left.
Its the bottom left one i am trying to put on the block please help. Even to explian how it goes would help.
Old 03-21-2009, 09:53 PM
Village Troll
SS RRR's Avatar
Well if it doesn't fit then try the other bracket.
IIRC the upper left bolts to the pass. side of the block and the bottom right bolts to the driver's side of the block.
Old 03-21-2009, 10:12 PM
the upper left work on both sides for some weird reason. but the bottom left wont fit on either side unless im missing something.
Just look at the picture.
Old 03-21-2009, 10:18 PM
Village Troll
SS RRR's Avatar
I believe it goes like this:
Upper left: Bolts to passenger side block.
Upper right: Bolts to passenger side k-member
Bottom left: Bolts to driver's side k-member
Bottom right: Bolts to driver's side block.
Old 03-21-2009, 10:25 PM
Thats what i had figured but the bolt holes on the Bottom left just dont match up with the holes on the block.
Old 03-21-2009, 10:30 PM
Village Troll
SS RRR's Avatar
Old 03-21-2009, 10:39 PM
I got it not thank you. That is a stupid design on how they switch it all around.
Old 03-21-2009, 10:55 PM
AChotrod's Avatar
Glad you got it! I
