Mounting amp HELP!
I mounted mine to the carpet using some nuts and bolts. The carpet is pretty thick so the amps have enough padding underneath them and the carpet is so strong I don't have to worry about the nuts ripping out.
^^ That would be ok if it fit right. The sides of the amp rack look like a kid cut them out.
i layed a piece of 1/2" plywood down and just layed the carpet on top of it. Screwed the amp down to the wood through the carpet. The carpet keeps the wood and amp from sliding around.
sorry to bring back an old thread but.. how much room do you have between the tub metal and the gas tank. if i was to sink a quarter inch sheet metal screw into the bastard would i..uh..die or anything?
