Cam install help in a hurry please!!!!
Old 03-21-2009, 09:59 PM
litemup's Avatar
Default Cam install help in a hurry please!!!!
so im trying to finish up my head and cam swap and i am putting the crank pulley back on and with the old bolt i have turned it far enough to where it wont turn anymore and is moving the car forward when i try to turn it. I have the car in 4th and the e brake on, but the crank pulley is about a quarter inch or so off of the alternator pulley and a/c pulley so i dont know how to get it on any farther?
Old 03-21-2009, 10:13 PM
stevied916's Avatar
it will go on more. you torque the old bolt to 200 then the new one to 250
Old 03-22-2009, 12:19 AM
SS#1230's Avatar
are you using a big breaker bar with a long cheater bar on it? if not, try that. it will go on farther (obviously), but steady torque from a lot of leverage is better than jerky brute force.
i used a bolt that was about an inch longer than the stock pulley bolt so that i had more of the threads in the crank while the pulley was being started on the snout. i also used a strong washer with it. maybe the slippage of the bolt/washer let it slip on the pulley face. you may have a lot of friction from the washer area on the crank bolt. maybe try some grease on the washer area (dont get it between the snout and the pulley though!) of the crank bolt touches the pulley face....
am i making any sense? everything will bind up if the bolt has too much friction on the pulley. if it isnt sliding on the pulley face, it isnt going to turn anymore because it sure isnt going to spin the pulley on the crank....
Old 03-22-2009, 12:34 AM
LSX Mechanic
Damian's Avatar
You need to stick a big screw driver (or pry bar if available) in the u-joint of the driveshaft to keep it still. Some cars won't stay still even in 4th gear.
As for TQ'ing the pulley, I sure do hope you're using a torque wrench and not just going by looks.
TQ the old bolt to 230 ft lbs, back it out, and TQ the new one to 100 ft lbs. Done. The info posted 2 above me is incorrect. Do NOT tq the new bolt to 250.
Old 03-22-2009, 09:25 AM
vsocks1's Avatar
Where does the 100 ft. lbs. torque spec come from? Never heard that number anywhere before! Please explain!
Old 03-22-2009, 10:03 AM
blkbird's Avatar
I thought it was 240 on the old bolt. Back it out, put new one in and then torque to 37ft lbs, and then turn it 140 degrees.
Old 03-22-2009, 10:28 AM
Moderator
davered00ss's Avatar
You need to somehow hold the pully still. They do sell a tool for this. I cut one out of steel and welded in some bolts. I'll try to find a pic & post it up.
Old 03-22-2009, 10:33 AM
Moderator
This one is for a stock pully. bolts go threw the holes in the pully. Hole is for the socket to go threw. Hold it and tighten down. you can chain it to the k-member as well.
As for how to tq it, check out ls1howto.com
Old 03-22-2009, 10:34 AM
Mssingkid's Avatar
I put the car in 6th with the e-brake when i did mine. The higher gear helped stop the car from moving forward.. ::shrug::
Old 03-22-2009, 12:17 PM
Deerhunter-Z28's Avatar
That will work, I've always just torqued mine to 150ft lbs in 50lb increments and used red loctite on the bolt, never had a problem.
Old 03-22-2009, 12:39 PM
vsocks1's Avatar
Not really asking if it worked for someone...I want to know the source of the spec? Never saw 100 ft. lbs. torque spec for GM or ARP bolt. And the procedure does not call for red loctite although it works for many!
Anyone know where this 100 ft. lbs. torque spec is coming from?
Old 03-22-2009, 12:58 PM
It comes from a lot of heads/cam swaps...lol. I don't think there is a spec in a book somewhere if thats what you are asking.
Old 03-22-2009, 01:11 PM
Russ K's Avatar
Correct, and never use the bolt to install the crank pulley. Use a threaded rod and flat washers & then thread a nut on the rod to press the pulley on. I use an A/C clutch install bearing instead of the flat washers.
Russ Kemp
Old 03-22-2009, 04:51 PM
vsocks1's Avatar
100 ft. lbs. is much lower than what is recommended by ARP and I have heard the 37 ft. lbs. plus 140 degrees is way over 200 ft lbs.....so that is why I am questioning that advice. Many have had bolts come loose so why was 100 ft. lbs. chosen in all these cam swaps? Must be some basis for it and that is my real question and why I am confused!
Old 03-22-2009, 05:53 PM
LSX Mechanic
Damian's Avatar
It comes from 12 years of doing it and knowing what works
