Older F.A.S.T. system EDist ignition delete
For anyone that has an older F.A.S.T efi system (non XFI) (gray computer box)that required the EDist ignition box. The boxes can no longer be purchased from CompCams unless a dealer has them laying around still. The new XIM is not compatible either with the older systems as I was told. The MSD 6010 LS1/LS6 carbuertor controller will work with the older F.A.S.T. system and it also has the ability to do a low side two step as well the only draw back is the F.A.S.T. no longer controls the timing.
