Lunati 382 guys....please look
what size cams and power output did you get using this stroker displacement? Thanks. I use LS6 heads with .025 gaskets....same as milling .029 or so for clearance if you wish to comment.
Re: Lunati 382 guys....please look
I hit mid 470's rwhp with the Grand-Am Cam: 239/251 .570/.570 106, LS6 CNC heads, 3.73's, 2001 C5 6 speed. This setup would run 11.30's @ 124 with 1.8 60' with DA of +2000
Just converted to solid roller: 244/251 .689/.697 110 (haven't dynoed yet; still working on a few tuning issues)
8 Sec Tuner
I have a Lunati 382 Stroker in a 99 FRC Corvette M6.
With stage 2 heads and MTI X1 cam on a 112. I made 455 RWHP 440 Tq. I added a Z06 maf and airbridge now it dynoes 460 RWHP. And is currently broke due to a timing chain failure!
mine is going together now. I wimped out on my cam I went with 236 intake 240 exhaust .580 lif. I wont be posting up any dyno numbers as my car sucks on the dyno, But I will post up some track times when done.
Restricted User
H82BBAD - Let me know how yours turns out so we can compare some notes.
I used the rengade lobes I posted about this weekend, They will not be as fast as the xe-r lobes but should be very easy on the valve train parts. I went with it on a 112+2. I am also using 2.055 intake and 1.57 exhaust valves. I will let you know how it turns out but with my converter swap I doubt it will be very fast on the motor. It should rock on the hose though!
