2.02/1.56 on stock heads?
I picked up a set of stock heads a long time ago with 2.02/1.56 valves and 918 springs w/ the intention of getting them ported but I think it will be awhile longer til I have the coin for that plus the supporting mods I dont have yet. I had the heads checked out and cleaned up the other month with the intention of throwing them on as is for now. I have to do the intake gasket so figured I might as well throw them on along w/ the impala HG's I have while im in there. the next mod im planning after that is a cam in the 220*-230*/.550-.575 range, havn't narrowed down my choice just yet.. but after reading a post the other day im wondering if those valves are too big for stock heads. I have seen some people running them with stockers but I've seen people also mention valve shrouding.. are 2.02/1.56 valves to big for stock unported heads? would I see any more of a gain after I cam it with those valves + more compression or would valve shrouding cancel it out or even hurt perfomance more. so should I install them while my engine is opened up or take the springs off and put 'em back on the shelf till I have the $ to get them ported?
and anyone know when the search is going to work right again?
yeah the machine shop that I brought them too said they weren't seating properly so he fixed that for me. still not a good idea tho huh? what about these valves w/ an LE1 p&p job? would they still be overkill?
well my next round of mods which im planning on doing before it goes back on the road will be: cam, PR's, 1.6 RR's, EWP, double roller, rebuild the 10broke & install the 3.73's I've got laying around + a re-tune. these heads have 918's on them already and I was figuring if I have to do the intake gasket I might as well go a little deeper and swap the heads and throw the imp gaskets on. but I think I'll hold off on the heads now after getting some input. I had planned on getting an LE2 p&p job but I think I have to much stuff going on to afford it this year. I could probably manage an LE1 job this spring but I'm not going to keep the car off the road till I can. and I just updated my sig w/ all my current mods so you'd guys know...lol its not very long but its a strong runner for whats done.
thanks for the feedback guys! any other thoughts?
I had Llyod put in 2.00/1.56 when i had my LE1 heads done, i asked him about the gains and he said gain of 8-10 RWHP/RWTQ more from 2500 RPM on up over the 1.94/1.50 valves.
I would def get the heads ported with those valves, while you have the heads off if you have the coin do the cam at that time.
something else that should be checked if you go this route is the ptv clearance
if using a stock bottom end
