HCK with 100 shot
Old 03-22-2009, 02:26 PM
madmike9396's Avatar
Default HCK with 100 shot
What kind of times and hp would i make with the hot cam kit 100 shot full bolt ons and 373 gears ? Just wondering thanks to anyone with info
Old 03-22-2009, 03:16 PM
Badazz 97 TA's Avatar
9.5 @145mph......too many variables. I assume you have an auto w/ the 3.73's, correct? stock converter? anything else done to the car? hows the track prep where you go? whats the altitude by you?
any previous 1/4 mile runs with the car as it sits right now?
Old 03-22-2009, 05:01 PM
Nah i havent ran the car not sure what the altitude is but i live in N.C. This set up will be going thru a performabuilt trans
Old 03-22-2009, 05:51 PM
I8ASaleen's Avatar
Mid-high 11's.
Old 03-22-2009, 06:35 PM
thanks guys just trying to gather some info
Old 03-22-2009, 06:37 PM
registered user
ScreaminRedZ's Avatar
I would also guess in the mid to high 11 second range as long as you had a good converter and traction.
Old 03-22-2009, 06:39 PM
Thanks i may ditch the hot cam for custom ground cam
Old 03-22-2009, 07:28 PM
RamAir95TA's Avatar
Probably the smartest thing you could do.
Old 03-22-2009, 07:31 PM
My95Z's Avatar
Just make sure they know you are spraying when they cut the cam for you. I know its only a 100 shot, but you never know in the future if you decide to spray more.
Old 03-22-2009, 08:48 PM
yonerhottlt1's Avatar
I think that you definitely have the potential to run 11's with that setup. Im running pretty much that same exact setup but unfortunately havent been able to get any times at the track/dyno. bummer.........
Old 03-22-2009, 08:53 PM
So your running the HCK How do you like it?
Old 03-22-2009, 09:59 PM
BigZee71's Avatar
Im running the HCK with similar mods as the OP, 3:73's auto with factory converter and supporting mods. With 2:73 gears it ran a 13.5 in the 1/4. Its very streetable with an almost stock sounding idle (with this tune). You can make the idle chopy with a diff tune by IMO you sacrifice a bit of performance. People say its a wimpy biginner cam, but it works well with stock heads/cubes/ injectors. It dosnt have to sound like an all out drag car to run like a raped ape.
Old 03-22-2009, 10:01 PM
Sound like you have a lil sleeper going there
Old 03-22-2009, 10:45 PM
LM97Z's Avatar
Look at my sig., i ran that time with just bolt-ons & 100 shot, & theres still more in it, if your just wanting to get into the 11s, bolt-ons & 100 shot will do, especially with an A4 car, if you set it up right & you 60ft. really well (1.5s), you'll go lower 11s with the right cam & 100 shot, i'll soon have an 11.8 time slip with my junk, & it has 160K on it @ full weight.
Old 03-22-2009, 11:34 PM
BigZee71's Avatar
Thats not too shabby^^ A 9" with DR's makes for a good 60ft time. With my 2:73 the best it could manage was a meak 2.1 short time. Are you spraying off the line>?
Old 03-23-2009, 04:54 AM
Thats pretty good there
Old 03-23-2009, 08:19 PM
LM97Z's Avatar
I'm running a window switch, i have it set @ 3000 on/5600 off, those 60fts. are still weak at 1.80s, i'll most likely be able to get it in the 1.6s, or i hope, that may get me an 11.7x, not to bad for this old thing lol., on motor all i could muster was 2.00x, but on the sauce, i've driven it from a 2.15/1.98/1.80 with just those 3 runs, ran a 12.95 (let off), 12.51, then the 12.01, i'm leaving higher each time i run, that 12.01 was leaving at 2500, next time i'll try 3, maybe 3500 if the tires hold, hell its trapping at 6-6100 with these small tires & i feel the N20 kick out, so its loosing at the big end too, i'm sure theres 11.5-11-6s @ 116+ with a taller tire.
This is what you she looks like, but don't let those looks fool ya.
Old 03-23-2009, 10:03 PM
My car actually idles pretty smooth with the HCK as well but with longtubes and the cutout open it sounds pretty mean if u ask me. But i dont run cats nor mufflers with my setup and also have ported heads + intake and most of the boltons with a 125 shot. But like i said still no numbers from the dyno/track.
Quick Reply: HCK with 100 shot
