blow up my motor, pics inside
this is an 85,000 mile stock lq4. i guess it didnt like 9 psi.
number 5
number 7
number 7 cylinder
bare block ready for the machine shop
here is one run before it went, through a 4l80e and a slipping t-case
new motor will be stock crank, mahle pistons, eagle rods, arp head and main studs, and more boost.
number 5
number 7
number 7 cylinder
no meth on crappy CA 91 pump gas. there was oil blowing out the exhaust that was screwing up the afr reading, i picked up the motor used, the bottom end was very extremely dirty and there was fine metal shavings in the oil. it was just a ticking time bomb. but im not going to lie. i dont know much about this stuff.
could my piston melt like that because after it went the motor was idling for a while and i drove it around the parking lot on to a trailer and then off the trailer into the garage
piston looks like it chipped due to a lean condition. tops of the pistons were extremely clean looking, showing a lack of fuel. did you upgrade your pump and injectors at a minimum? maybe on the rebuild a wideband would help out on the tuning, if you did it yourself. what did the plugs look like?
