best route for running wires from battery to trunk?
Im ready to install my sterio in my my 97 camaro, need to run a power wire from the battery to the trunk
I couldnt realy find any spots in the firewall that seemed easy.
Do I have to drill one?
any one have any info on the easiest wireing route?
Thanks.
Thanks.
On my T/A, I removed the 2 bolts that hold the computer down on the passenger side of the firewall and moved it out of the way without disconnecting anything, then used a piece of wire snaked through the factory waterproof grommit behind it to get into the interior, following the existing wiring. Very simple and should be the same for the camaro.
