Single Digit Club - Is a 6.33 1/8 enough?
longrange4u
03-23-2009, 02:49 AM
Is a 6.33 @ 113 in the 1/8 good enough for the 9sec club? Or do I need to pack it to a 1/4 mile track?
Dragkid1917
03-23-2009, 11:25 AM
a 6.33 is on the bubble, but considering your going 113 mph at half track, and your a turbo car (I think? I cant understaind your exact setup given in your dig) Id say your definatly in the 9's given another 660 feet. My camaro runs 6.15-6.20 @111 ish at half track and clicks off mid 9.7's. And thats N/A
should be good for 9.80 range or possibly better. Usually you can multiply the 1/8th ET by 1.55-1.56 is a close indicator. Being a turbo car I would think you would pick up more on the big end than an NA setup.
ls2 bait
03-23-2009, 06:50 PM
theirs enough their for sure......but its up to the powers that be for a title change :angel:
CodeRed2000SS
03-24-2009, 08:03 AM
its enough, but like stated above, its up to the moderators
longrange4u
03-24-2009, 01:29 PM
Thanks for the feedback fellas... Yea its a PT88 turbo setup... and it has more to give!!
Coach 02 A3 Z/28
03-25-2009, 01:54 PM
6.33 x 1.573=9.95709 but for you to get a 9 second title you need to run the 1/4 mile. You should have no peoblem running in the 9's. Congrats on the run.
Coach
Reboot
03-25-2009, 02:34 PM
two weeks ago I ran a 6.34@107.8 1/8 mile and ended up with a 10.002@135.9 1/4 mile...I'd say your good with your 1/8 MPH....That's moving
MORETHANQUICKSTANG
03-25-2009, 03:25 PM
yes it is!
longrange4u
03-25-2009, 04:38 PM
Coach
Thanks Coach..
Fair enough... we will run her in the 1/4th in about a month.
Jared
Coach 02 A3 Z/28
03-25-2009, 04:47 PM
Good luck Jared.
Coach
ls-who
03-29-2009, 01:03 PM
my ol turbo car once ran a 6.7ish in the 1/8th.. but ALMOST a 9 flat on the other end..
at 1/8th i was trapping 140 mph tho.. lol
that was in the tnt stages of trying out what would get the little motor spooled up .
Elite_Hot_Rod
03-31-2009, 12:54 PM
Umm a 140 in the 1/8th is like a 5.2X/5.3X, your numbers don't work. I know it's back halfing but.
ls-who
04-03-2009, 10:01 PM
yes sir.. the 5's followed suit.. that was a broken up pass.. some initial tnt passes while having MAJOR trouble..
I8UR4RD
05-04-2012, 08:21 PM
140mph in the 1/8th? what was the setup.
Heater
05-05-2012, 06:42 PM
113 is nice for the 1/8th and should roll out pretty good in the 1/4 with your turbo.
stevieturbo
10-27-2012, 06:13 PM
Mine was 6.52@113 at the 1/8th and 9.98@143 over the 1/4
then 6.41@113.8 at the 1/8th for 9.85@145 over the 1/4
M6 YSi car, circa 3640lbs
6.3 should be well into the 9's
Mrmooney
11-07-2012, 08:28 PM
As others have said should be good for 9 mid to high 9.
