E-cut questions
E-cut questions
i have a 98 ws6, i wanna put an E-cut on it, i have read other threads and from what i understand the best place to put it is right under the back seat? is that the best spot for it?
which E-cut has been the most reliable?
and where and how do you run the wires? do you have to drill a hole in the floor?
i would also like to see some pics please if anyone has them...any and all info will help thanks alot guys
that is the best place for a cutout.
as for brands the 2 best brands are QTP and DMH.
dmh having a 4yr warranty and qtp i believe has a 1yr warranty.
you dont have to drill any holes theres a plug that its under on the rear passenger seat ujust have to splice it up alittle and run the wires through there.
In my personel opinion, i would with a DMH E-CutOut from WS6 Store.. http://www.ws6project.com/user_stor/...oducts_id=2780
And where it asks if you want the QTP SS CutOut, select YES
question
can somebody post some pics of exactly where under the back seat to put the cut out? also do you have to remove the back seat and the carpet to run the wiring? thanks for the help guys!
here is a pic of a cutout under the rear passanger seat. You can see the black rubber grommet where you will need to run the wiring inside the car
I'm a six speed car and i just ran my wiring up the shifter boot down the side of the tranny strait to the cut-out, worked great. The cutout is a 3.5" BadlanzHPE cutout. www.BadlanzHPE.com
