flow numbers off my old 853 heads
well i got these flow tested the other day and was wondering what you guys think of these numbers?
flow intake exhaust
.200 128 101
.300 285 135
.400 226 165
.450 244 174
.500 256 181
.550 262 187
.600 262 192
.650 265 195
.700 265 196
.750 250 196
i pulled these off and had replaced them with PRC 2.5 5.3L heads. did i make a good move on the switch or should i have stuck with these heads?
flow intake exhaust
.200 128 101
.300 285 135
.400 226 165
.450 244 174
.500 256 181
.550 262 187
.600 262 192
.650 265 195
.700 265 196
.750 250 196
If the new heads flow more than the 853's do up to the rated lift of the cam(or cam you plan on going to) and you have the exhaust system set up for the additional flow, then you did the right thing - if not, then you wasted your money............
i paid to have them flowed. theyve been sittin in my garage and i figure id get numbers so that i could sell them. they have been ported by a local guy named joe crane. i will be having my current heads flow tested because im thinkin of doin the switch to LS6 Stg 2.5 heads.
