Putting together nitrous motor what pistons/rods?
Since somehow my fuel solenoid or timing tuner failed to cause my motor to run lean and detonate im wondering what would be the piston and rods to get? The motor will most likely remain stock headed and cam only. I would like to run a 250-300rw shot with a dual stage plate setup. I plan on using the stock crank and block (staying stock ci) so basically iam curious as to what people would recommend to go with piston and rod wise since im assuming they are the weakest links I also plan on doing rod bolts.
