Fueling & Injection - Are 60lbers to small for me?
barnat
03-23-2009, 08:33 PM
hey guys i bought a brand new set of 60lb injectors from Nate at Nasty performance last year for my APS TT kit and i ended up building a forged 6.0 which is 9.5 to 1 CR and plan on running 13 to 15 psi on a SD tune. Will these 60s give me enough fuel? if not ,what size should i go with?
elias_799
03-23-2009, 08:51 PM
the 60 lb injectors should get you to 750whp mark no problem. i don't know how much power you will throw down on 15 psi because i do not know what turbo, heads............, you have.
barnat
03-23-2009, 09:03 PM
Aps twin turbo with LS6 heads and intake on a forged LQ9 6.0 block!
2001-WS6
03-24-2009, 09:51 AM
Yes, they move plenty of fuel and a boost referenced regulator keeps things pretty easy to manage when you want to open them up a bit more. I'm still runing them in a 3,700lbs car that runs 9.4s at 148mph. So you'll be safe for a while. :)
Rick
AgFormula02
03-24-2009, 11:04 AM
60# are at 92% duty cycle in my car.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
