ls2 vs ls3
Old 03-24-2009, 01:05 AM
kngkahious's Avatar
Default ls2 vs ls3
what are the differences between a ls2 and ls3 ? i have allway's been curious now i'm looking to build an engine and am trying to justify any cost difference's .
Old 03-24-2009, 02:25 AM
rsz288's Avatar
LS3 has 150cc more capacity, a slightly stiffer, stronger/more durable block (based on GM press), and better L92 style, higher flow heads with larger valves, and matching intake. Also has a slightly better stock cam, and generally makes more power all things being equal.
Do I now hear a debate coming.....
Old 03-24-2009, 07:16 AM
SweetS10V8's Avatar
Basically it has a .060" larger bore, and better heads. The other details are that, just minor details.
Old 03-24-2009, 10:42 AM
kngkahious's Avatar
i dont think i will have a need for the ls3 block then for( .06 ) i'm not going to be pushing it hard enough . i was going more for just the block vs the ls2 block. i'm going to use aftermarket heads crank everything.
Old 03-24-2009, 02:11 PM
Tainted's Avatar
ls3 for the win. im researching myself and it seems mod for mod the ls3 makes better numbers every time and has even better parts.
Old 03-25-2009, 01:22 PM
trumperZ06's Avatar
LS3 breathes better... but seems to have oiling issues on a road course.
There's a thread over @ www.sccaforums.com in the T1-T2 section.
Old 03-25-2009, 08:54 PM
SweetS10V8's Avatar
Which is mainly from the heads, not the .060" larger bore.
Old 03-25-2009, 10:43 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Price....
Old 03-25-2009, 11:16 PM
rsz288's Avatar
Oiling issues? Do you mean burning oil, or oil starvation?
If its starvation you are referring to, thats why the Z06 has a dry sump.
Old 03-26-2009, 09:06 AM
trumperZ06's Avatar
Oil starvation in high speed left turn sweepers... seems to be a major issue with the LS3. SCCA is likely to allow adding a dry slump system for the LS3 engines.
Everyone's questioning potential horsepower gains when using the dry slump system.
As many have mentioned the LS3 heads evolved from Chapman's LS7 head design.... ergo, they breathe better.
Quick Reply: ls2 vs ls3
