Gears & Axles - My rearend is leaking........
sway99bird
03-24-2009, 08:04 AM
I have a 99 Trans am (A4) with the stock 10 bolt out back, moser axles everything replaced 4'11's, posi. Here recently I have had to remove the back cover on it twice. And after i'm done I put everything back together replace the gasket if needed, and after I drive the car and the axle gets warmed up the bolts come lose and it starts to leak:mad:. The second time around I put washers and lock tight and it still does it, so what do you think ?
Sway
omcar
03-24-2009, 08:19 AM
get an LPW cover and torque bolts to specs.
Bad30th
03-24-2009, 10:22 AM
You can use some RTV around the gasket to seal it up as well. Make a nice seal on both sides of the gasket and circles around all the bolt holes on both sides.
(and agree with the above, torque the bolts to spec, and a TA cover is a cheap investment)...
Rob (Bad30th)
CodeRed2000SS
03-24-2009, 11:25 AM
yep, that will fix your problems
sway99bird
03-24-2009, 01:18 PM
Thanks guys I will look into that
Sway
wht01ws6ta
03-25-2009, 07:54 PM
I've never replaced one without using RTV and have never had a leak.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
