Need a quick "How to" on installing a 2-step
Looking in to getting a 2 step for use with my trans brake but money is a little bit of an issue right now.. the easiest one ive seen is the lingenfelter launch controller as it is pretty much plug and play but is there a way to wire in just a normal MSD 2-step? thanks any help is appreciated, factory computer is still being used if that makes a difference
I just installed the Lingenfelter 2 step last night. it took 15 minutes start to finish wired into the tbrake. I still need to connect the transient voltage diode to the tbrake solenoid tonight before I test it.
Anyone else using the transient voltage diode with their lingenfelter 2 step installs? I'm not running a relay on the tbrake. Power is coming straight from the battery.
Edit: I have lnc-03. plug the coil harnesses in, connect the yellow wire to the tbrake or line lock button, connect orange wire to switched power. set both 2 step limits to desired rpm with a mini screwdriver....done
Ease of install go with the lingenfelter...if you want something custome tailored and extremely versetile, go with a Synergy...time consuming to hook up, but its not hard..and if the 2 step box dies, your car will still run since it dosnt intercept the signal
That's what she said...
I have one in mine, and it works great. I have the 2-step setup so that when it's on the 2-step it disconnects my nitrous. Also, when my nitrous is spraying, it pulls timing. Extremely simple to hook up.
selling my new lingenfelter 2-step...Too noisy for me
https://ls1tech.com/forums/lsx-parts...l#post11314661
If the Lingenfelter dies, you just unplug the damn thing from the coil packs lol.
whats the benefit of running a 2 step on a automatic nitrous car?
From what i understand it helps build boost at the line in an FI car but what does it ofer for N2O and NA setups?
It lets up set your 2-step to your stall speed ,so when your at the line you can hold your stall and put the peddle to the floor, Then release the brake and go bye bye I have the Harlan 2-step and i have my nitrous wired to it ,And it disables the nitrous while the 2-step is active and plus hold my stall at 4400 rpms, And when i let off the brake peddle my 2-step deactivates and my nitrous activates.
If your nitrous goes hot when you turn it on, and a ground activates to complete the circuit only when spraying (like mine), it's a bit more complicated. I have a relay wired up so that the 85 and 87 pins have +12v at key on. 86 is connected to the ground provided only when spraying (my FJO controller). 30 is then connected to the retard activation wire.
This way, when the ground gets applied by the nitrous controller (86), it causes the relay to close (87+30) and send +12v to the timing retard wire of the 2-step. Make sure you test it out before use though.
crader_2000@charter.net
