Gears & Axles - Will it Fit?>
View Full Version : Will it Fit?>
NeXuS
03-25-2009, 08:21 AM
Ok i have a 2001 Camaro Z28 with Trac control.. I was wondering if it will bolt into my 96 Trans AM without Trac? My Luck it wont but its a shot in the Dark...:bang:
NeXuS
03-26-2009, 07:51 AM
Bump it up... the ls1 rear has TCS the LT1 Doesnt.. But i dont car about TCS i just want to know if i can swap them...And i dont care about ABS working correctly...
STEEPSS
03-29-2009, 02:02 PM
you can swap it, but you most likely won't have ABS. as far as mechanical, everything should be a direct swap.
