power to manual windows
Looking for any information to swap the power windows in a trans am to the manuall cranks from a v6? I'm building a drag car and the passenger side goes real slow and both switch housings are broke
rivets hold the motor in place. drill the rivets out, and replace it with the manual crank. these require bigger than normal rivets to replace. the most common rivet tool is the "big daddy". if you dont have a rivet gun then get your manual cranks installed and drive to a body shop and they will quickly rivet it in for ya for a couple bucks. other than than that thats about it.
hell I want to do it just because im tired of replacing motors....
but what about when you get a cage? i can easily reach it now without one, but having a door bar would probably be a PITA?
Chad
Chad
The people that say the weight is not any diffrent are not including all the wireing . They are 10 lbs of wires and if you are going for a drag car, are removing the fuse panel ? if so get the mirrors and door looks . All the wire i pulled the last time was 15lbs. Not counting how much junk is gone. I did mine last year and i did not use a rivet gun. i used bolts with washers ans lock nuts. easy as pie the only issue with a trans is door panels. I still dont have any, the speakers are in the way of the cranks. Also all the hools in the door are already there. the first took 1 to 1 1/2 hours the second 1/2 . But i have changed a few motors and had all the rivets drilled. as for the wiring need the dash out but if it is a drag car it will be out for somthing else. wait untell then because that wire i swear makes loops inside the car . it is a bitch to remove all of it. i will try to find the pic of all the wire i took out when i pulled the windows
That is my plans, im an running a 1/8" plastic skin with just the manual lock rods and my drivers mirror housing is broke so they are getting replace with manuals.
I already have the dash out to get the a/c box out and half of the now useless wires are removed.
Im going to go ahead and make a topic in the Wanted section looking for some.
Don't do it...weight savings is VERY minimal...I weighed the two regulators and other parts together a long time ago. It sure is nice to be strapped down in the lanes and just push a couple of buttons to have some fresh air when needed! Good luck either way. Dave
Sure is a bitch for the motor to fail and the window will go down but not up. art an NMCA race and break the regulator trying to force it up. Dont think it cant happen that was the main reson i went to manuals. I had a power pass and man driver for 2 years. Then ditched the powers all together.
