Headlight Motor Question
Old 03-25-2009, 12:43 PM
ArkBird96's Avatar
Default Headlight Motor Question
Will a headlight motor from a 1996 firebird v6 work in a 2000 Formula or did they change the design? I have the dreaded "grinding" problem in my 2000 but my 1996 motors are both fine. Would it work to swap the motors?
Old 03-25-2009, 04:02 PM
Ungrounded Moderator
WhiteBird00's Avatar
No, they are different motors. 93-97 Firebirds had single lamps on each side, 98-02 had two lamps on each side (separate highbeam and lowbeam) so the housings and the motors are different.
Old 03-25-2009, 04:11 PM
ArkBird96's Avatar
OK. I will just deal with the ones on the 2000 then with new gears or new motors. Thanks!
