Buy or run?
Buy or run?
Ok planning a cam swap this summer and just saw an add in the local classifieds for some heads off a gen III silverado SS
which I believe is the LQ9? the catch is the guy claims the pcm shorted so it has bent rods.....Is this worth picking up to rebuild or is it Fucked...cost to rebuild so I can drop em' on?
damn mod fever making me itch!
Ok planning a cam swap this summer and just saw an add in the local classifieds for some 317 heads off a 2003 silverado SS 6.0L which I believe is the LQ9? the catch is the guy claims the pcm shorted so it has bent rods.....Is this worth picking up to rebuild or is it Fucked...cost to rebuild so I can drop em' on?
guess I better go look at em', what am i looking for besides obv. cracks n ****, the guy is asking 150 for them, are these heads a good improvement over stock 241's or should I just wait til i can afford prc 2.5 5.3's. I am a college student so every dollar counts.
Those heads will likely flow comparable to 243 heads but with the 72cc combustion chambers, your CR will drop by almost a full point, likely negating any gain seen from more cfm of airflow. Those heads are great for FI builds, for NA, look for a nice set of 243's. And if budget allows, get them ported.
