TCI or PCS tranny controller
TCI or PCS tranny controller tcc pressure control
Just wanted to get some input on what anyone is running their tcc pressure control at for the track with a 4l80e. Thanks
Without any knowledge of the above variables I can say that you should use the datalogging feature with a laptop or their D200 / TCI logger and monitor TCC slip which largely provides the answer to your question in the logs itself.
RPM Stage V 4l80e 5 disk Precision converter 950rwhp 3.55 28/10.5/15
I spoke to Russ at PCS and he gave some tips for the lockup at the track. One thing he suggested is to make the lockup % per second 1000 or higher and the starting percent 100. This should make it lock up as fast as possible.
