spark plug ????
Old 03-25-2009, 08:12 PM
bigtls1's Avatar
Default spark plug ????
is the AUTOLITE brand spark plug any good for nitrous?
i hear everybody runnig the NGK tr6's but nothing about autolite.
Thanks for the help
oh yea the Autolite 103's
Old 03-25-2009, 08:20 PM
Greg Pippin's Avatar
I dont know about the autolite, but i use the NGK's in my T/A.
Whatever you do, DO NOT use the stock GM plugs if you are going to use nitrous.
Old 03-25-2009, 08:53 PM
AutoRoc's Avatar
I've seen the 103's used at 200+ jetting and they always looked great. goodluck
Old 03-26-2009, 09:38 AM
purdueranger's Avatar
do you have an O'Reillys auto parts store close to you? if you do then go there and get the NGK plugs for 1.99 a piece and they come with a one year warranty and just take the old ones back and get the new ones when needed.
Old 03-26-2009, 09:50 AM
Nick@HSW's Avatar
Autolites are a nice plug. Nothing wrong with them at all.
Nick
Old 03-26-2009, 10:04 AM
CodeRed2000SS's Avatar
i ran a NGK tr6 until i went to a 200 shot. now im running a Autolite AR-93.
Old 03-26-2009, 12:06 PM
robsquikz28's Avatar
if the tr6 plug is comparable to the auto lite 103 then if your using a tr7 plug what auto lite number would be comparable?????
Old 03-26-2009, 12:48 PM
Nick@HSW's Avatar
They really don't have much in that heat range. The next step up would be a AR474.
Nick
Old 03-26-2009, 12:58 PM
white2001s10's Avatar
Ar472
Old 03-26-2009, 01:17 PM
bigtls1's Avatar
Nick
so the 103's are the correct plug right?
im running a 100 wet shot
Old 03-27-2009, 09:05 AM
Nick@HSW's Avatar
Yes they will be fine on that size shot.
Nick
Old 03-29-2009, 11:21 PM
madclown's Avatar
Will the TR6's be ok for a 150 Wet Plate kit?
Old 03-30-2009, 12:00 AM
WS6Power's Avatar
Yep, the TR6`s will work great N/A and with the 150 shot.
Old 03-30-2009, 12:31 AM
02 BLK WS6's Avatar
Autolite 103 = NGK TR6 - 1 step colder
Autolite AR94 = NGK TR7 - 2 step colder
Autolite AR93 = NGK ? - 3 step colder
LS1 Stock and AFR
Thread – 14mm
Reach - .708”
Socket – 5/8 hex
Seat - Taper
Stock Heat Range: 5
Gap: .060
Plug: NGK TR55 (stock number 3951); NGK TR55IX (stock number 7164); Autolite 764; Denso IT-16 (stock number 5325)
Nitrous (one step colder)
Heat Range: 6
Gap: .035 - .038
Plug: NGK TR6 (stock number 4177); NGK TR6IX (stock number 3689); Autolite 103; Denso IT-20 (stock number 5326)
Nitrous (two steps colder)
Heat Range: 7
Gap: Consult
Plug: NGK BR7EF (stock number 3346); NGK TR7IX (stock number 3690); Autolite AR94; Denso IT22 (stock number 5327)
Nitrous (two and a half steps colder)
Heat Range: 8
Gap: Consult
Plug: NGK R5724-8 (stock number 7317); NGK TR8IX (part number 3691); Denso IT-24 (stock number 5328)
Nitrous (three steps colder)
Heat Range: 9
Gap: Consult
Plug: NGK R5724-9 (stock number 7891); Autolite AR93; Denso IT-27
Nitrous (four steps colder)
Heat Range: 10
Gap: Consult
Plug: NGK R5724-10 (stock number 7993); Autolite AR92
Quick Reply: spark plug ????
