How does one completely delete the knock sensors in EFILive?
Old 03-25-2009, 09:26 PM
The Dragon's Avatar
Question How does one completely delete the knock sensors in EFILive?
Got both codes and I don't wanna waste time chasing down the problem whether it be a pinched wire, bad harness, or bad sensor(s). (nor do I have the time or resources to do so )
How do I delete them in the tune so it doesn't throw the code and pull timing?
Thanks!
Old 03-26-2009, 05:30 AM
BLK02WS6's Avatar
Change the codes to not reported and zero out all knock retard tables...
Old 03-27-2009, 07:55 AM
poconojoe's Avatar
It will be a lot easier to fix the problem, when you blow the motor, after you disable the knock sensors. Been there, done that
Quick Reply: How does one completely delete the knock sensors in EFILive?
