Flashing SES light(Misfire)...Disable?
flashing SES is misfire- If you have a big cam or heavily modified car the car needs a good tune - if you dont then something is wrong. - Seems silly to say no ****
Car misfires when either something is wrong, or improperly tuned... shutting off the light is not "a good tune" And it shouldnt take much of any time to ge tthe car to not do that. By only disabling the SES you are doing the car a dis-service.
all that disclamer out of the way - you need to load the scanned and find out what code is beind set - write that code / codes down and go to ur tune
under engine diag - DTC codes - there are a list of all possible codes- find the ones listed from the scanner and uncheck the box for SES enable - and change the report type to " no error report "
1 Post
Go to the misfire tables under engine diagnostics and raise up all of the numbers (other than the maxed out 32767's) by 50% or so. Some people just change them all to 32767 which essentially turns the misfires off all together... raising the numbers keeps the misfires enabled, but doesn't let "false misfires" due to the cam trigger the SES...
go to the misfire tables under engine diagnostics and raise up all of the numbers (other than the maxed out 32767's) by 50% or so. Some people just change them all to 32767 which essentially turns the misfires off all together... Raising the numbers keeps the misfires enabled, but doesn't let "false misfires" due to the cam trigger the ses...
thank you.
Because I stated clearly in the title/post that I had an MS3 cam'd car that was flashing the SES(misfire). You felt you either needed to repeat this info to me just for ***** and grins, or you never read anything in the first place and just immediately turned into LS1tech pro mechanical engineer like 85% of the other members on here.
Thanks for the info. Now I know what a misfire is.
I did that for the O2 Heater test and it passed right away. I just did that for the EVAP codes and the Secondary Air codes...SO I'm gonna go write this tune and drive it and see if at least one passes.
I can pass the emissions test if only one code is still incomplete...So hopefully it works out.
