What push rods for Z06 cam
its a stock ls1 with patriot dual springs and an 04 Z06 cam i was told 7.425 just making sure because i will be ordering then tomorrow thanks
I changed the heads to 243 with the Z06 valves when I did mine so pushrod length was the same and I could avoid the issue...
However since I assume you aren't changing that and haven't milled your heads, you should do the 7.425's. If you use the 7.4's the motor will probably still run but the preload won't be quite right.
