Fueling & Injection - Racetronix Install Complete
Joker98
03-26-2009, 03:02 PM
Well I just gone done installing my Racetronix pump and Hot-wire kit. I must say, Very nice product! Everything was plug-n-play and was a breeze to install. I used the trap door method to get to the pump so that made it easy. The instructions are very good..Colored pictures and all. Took me 2.5hrs from start to finish. Fired right up on the first start and I verified 62psi @ idle. Just chiming in to let anyone thats lookin at this kit that I highly suggest it. Thumbs up to Racetronix!!:thumb:
gogaurav
03-26-2009, 06:55 PM
where did u find pic and the trap door where did u put that
tording99Z28
03-26-2009, 07:17 PM
I second this post. I just finished mine a little over a week ago and had the same results. Very nice product with good instructions.
officermartinez
03-28-2009, 06:47 PM
Congrats.. I did my Racetronix and wire kit (LT1 engine) about 6 months ago.. I did NOT do the trap door method. OMG, it was quite a bit of work. I got everything installed but the in-tank fuel meter/bar thing was off just a bit. As a result, my gas gauge showed EMPTY even though I had a 1/2 of a tank of gas. So, I had to take EVERYTHING down again! This time around, we used a small scope/camera and got it set properly. Whew.. But, the upside is, BYE BYE stock fuel pump.. woohoo!
JFM-jr
03-28-2009, 06:59 PM
This should be helpfull
http://www.gonicd.com/intankinstall/intankpumpinstall.html
346ci
03-28-2009, 11:00 PM
Glad to hear that, I've been eyeing the racetronix pumps for awhile now
98Camarod
03-29-2009, 06:46 AM
Do you have any pictures for your hotwire kit or could you tell me if you used the top plug? All the pictures I've found used the bottom and I can't get ahold of racetronix or anyone thats done it on a 98.
Racetronix
03-29-2009, 11:05 PM
There is only one 8-position gray plug that your sender plugs into beside your diff.
Remove the red lock and unplug the sender connector from the chassis connector.
Plug the sender connector into the RX harness and re-insert the red lock.
Plug the RX harness into the connector on your chassis and replace the red lock.
98Camarod
03-30-2009, 05:21 AM
I forgot to post back in here. I did that this weekend. All is well. The instructions provided shouldn't have a different picture that has two 8 pin connectors and then using the bottom connector.
I didn't see any fuel pressure increase after the install either. It's the same as it was before.
transammiller
04-15-2009, 06:49 PM
i have a 98 what is so different with my car?
The Fugitive
04-16-2009, 08:24 PM
you have a metal tank w/out a bucket (internal baffle) you also have a few different connectors with the hotwire kit.
98TA6.0
04-17-2009, 01:25 AM
i have a 98 as well. i realize the wiring may be different but what i'm interested in is if i can do the trap door method the same as the 99-02 tanks? i dont wanna go cutting huge holes in my car. internal baffle? how does that make the install different.
Racetronix
04-17-2009, 02:52 AM
It is best to remove your metal tank to clean it out and check for rust etc.
The Fugitive
04-18-2009, 07:31 PM
the internal baffle on the metal tanks causes it not to need that plastic bucket I think. I am in the process of doing mine but I need to run more fuel out of it for the next weekend to i can drop it. I think the best person to ask is Mighty Mouse as he has already done it.
MY99TAWS6
04-19-2009, 01:13 PM
If you do the trap door on the 98 the pump is located higher up towards front of the car then the 99 cars.
98Camarod
04-19-2009, 01:19 PM
98's need a larger hole because of the metal lines that come off. You have to cut all the way to the front of the hump.
The Fugitive
04-19-2009, 11:29 PM
that big of a hole for the fuel tank opening??? I have a 99 with a metal tank and this just making me not look forward to doing it. does anyone have pitures of a 98/99 metal tank trap door?
