Am i in denial
Am i in denial
I finally got all the parts for a cam swap in my 95 formula and i was just looking around the engine while it was on and i saw the oil dip stick leaking out oil. PLEASE somebody tell me it could be something else. DENIAL DENIAL
Possibly blow by? Do a leak down test. And check the PCV.
Just pull the oil fill cap while the engine is running and look for "puffs" of smoke comming out as you lightly rev the engine.
It could just be something random, don't jump to conclusion. Also sometimes the dipstick will leak a little where it goes into the block, just use a little silicon and it will seal right up.
Has it ever been out? If it has and it never had silicone put around it and taped in far enought it will leek. There is also a bolt that holds it in, check to be sure that is there.
