Fueling & Injection - Were can i get a locking gas cap
View Full Version : Were can i get a locking gas cap
LS1FIRE
10-22-2003, 02:11 AM
Do yall know were i can get a locking gas cap for a 98 trans am. i just cant find them anywere.Do they even have a locking gas cap for 98 to 02 f bodies? :confused:
blk~2000~Z28
10-22-2003, 04:54 AM
Locking gas cap (http://www.ls1tech.com/threads/showflat.php?Cat=&Board=UBB1&Number=792326&Forum=U BB1&Words=sugar&Match=Entire%20Phrase&Searchpage=0 &Limit=25&Old=1week&Main=790866&Search=true#Post79 2326)
Try this link, someone posted the GM part number and price.
slow
10-22-2003, 11:12 AM
anybody know if there is a locking gas cap for the 98's as they use a different cap than the 99-02 from what i have read.
Ryan.
LS1FIRE
10-22-2003, 11:24 PM
Yeah i also have a 98 I wish i knew were to get one.
Eiyse98ls1
10-26-2003, 02:07 PM
from what ive read. there isnt one that fits our 98's.. ive tried several but none fit. ive also ordered one through gm parts #'s and that didnt fit.. i think us with 98's are SOL
Scalpel
10-26-2003, 02:33 PM
Could the 98's swap out the portion of the gas fill for the same portion on the 99+ so one could use the locking caps?
brianwetzel
08-27-2004, 12:28 PM
I was wondering the same thing. I really want a locking cap for my 98 but it is not available from any supplier. Has anyone done a successful 99+ locking cap merge with the 98 lower section?
LS1FIRE
08-27-2004, 06:21 PM
98 lockng gas cap problem was solved. Buy acdelco part number# 2266-0006 And grind down the tabs a little and it should fit perfect.
MIGHTYMOUSE
08-31-2004, 10:21 AM
as above.. it will work, just cut it down some.. i got mine from NAPA 703-1643
brianwetzel
09-07-2004, 10:56 AM
I noticed the original 98 cap does not have the vent in the center like the 99+ does. Does anyone know why the difference? Will using a vented cap cause problems on the 98 car? Thanks, Brian.
LS1FIRE
09-08-2004, 01:17 AM
I wouldnt worry about the air vents just buy the part number above and grind down the triangle parts on each side and it should fit perfect.
LS1FIRE
11-02-2004, 12:22 AM
Locking gas cap problem solved. http://www.ls2.com/forums/showthread.php?s=&threadid=66574&highlight=locking+gas+cap It was solved on the other forums awhile ago. just wanted to post the link. ;)
