View Poll Results: 90mm (already have it), 100mm, or No MAF
90mm (already have it), spend $ elsewhere
2
22.22%
100mm
2
22.22%
No MAF
5
55.56%
Voters: 9. You may not vote on this poll
408 MAF? 90mm 100mm or No Maf
Old 03-27-2009, 08:46 AM
LS1Marrow's Avatar
Default 408 MAF? 90mm 100mm or No Maf
408 w/ L96 intake manifold (90mm inlet) L92 heads. So I already have sourced a cheap 90mm maf, should I stick with this or will it be a bottle neck? I have a 92mm TB, with inlet diameter of 102mm. Should I drop the $250 on a 100mm Maf or just stick with what I have and spend the cash elsewhere. I am goingto get it dyno tuned soon, and dont want to find out its restrictive and have to go back if you know what I mean. Thanks, reasoning behind your decision would be great!
Old 03-27-2009, 11:42 AM
Restricted User
2001 Pewter WS6's Avatar
I made 540rwhp on my old 408 with a GM Screened 85mm MAF. Spend it else where
Old 03-27-2009, 12:21 PM
witry's Avatar
i voted no maf but since you have one then its a tossup but id go with a SD tune and sell the one you have
Old 03-27-2009, 02:48 PM
NemeSS's Avatar
might as well go with a SD tune.
Old 03-27-2009, 03:09 PM
LS1Marrow's Avatar
i have read there is not much benefit if any with sd if your NA (which I am and most likely will be for a while) opinions?
Old 07-11-2009, 08:44 PM
GoFast908Z's Avatar
^ would also like to know...
