LQ9 or LQ4
Old 03-27-2009, 09:49 AM
1bdtrk's Avatar
Location: Currently, Zormat, Afghanistan....Home staion, FT. Richardson, Alaska
Default LQ9 or LQ4
What is the difference between the two? Which Is better? I tried the search but no dice.
Old 03-27-2009, 09:59 AM
87silverbullet's Avatar
The biggest difference is the compression ratio lq4 is lower than the lq9. Someone will chime in on what they are since I have forgotten what they are. I think the lq4 is 9.3 or something close to that.
Old 03-27-2009, 10:04 AM
Isolde's Avatar
According to Will Handzel, the main difference is pistons. LQ9 got coated skirts and 10.1:1 flat-tops versus the LQ4 at 9.4:1 circular-dish, uncoated.
Old 03-27-2009, 10:07 AM
fknsmshn's Avatar
^ Werd. Thats what Ive heard.
Old 03-27-2009, 11:40 AM
1bdtrk's Avatar
so both blocks rods cranks are the same? minus the 99-00 lq4 cranks which wont bolt to the t56 and 4l60?
Old 03-27-2009, 01:17 PM
redchevytruck's Avatar
the crank reluctor wheel are different... lq4 has a 24x and the lq9 has a 58x
Old 03-28-2009, 01:50 AM
1bdtrk's Avatar
So who here has a stock bottom 6.0 or l92 in their f body?
Old 03-28-2009, 01:53 AM
ssick1's Avatar
the only diffrence is the heads the lq4 has lower compression and the lq9 has higher compression but its the same block
Old 03-28-2009, 02:43 AM
Soul TKR's Avatar
I do...
basically the differences have been mentioned already...
the LQ4 pistons are dished for lower compression... ideal for boosted applications
the LQ9 are flat topped... better for NA cars
both are iron blocks
in my case i have an LQ4, but I milled my heads to raise my compression back up.
Old 03-28-2009, 02:57 AM
ssick1's Avatar
Originally Posted by Soul TKR
I do...
did u like ur 6.0 better than ur ls1 motor?
Old 03-28-2009, 04:41 AM
1bdtrk's Avatar
I do...
what H/C/I combo you using? hp/tq? You like it better?
Old 03-28-2009, 04:24 PM
99LS6SS's Avatar
So a 2002 LQ9 will mate with a T56? And what crank would you need to buy to go back to the 24x reluctor? Will any aftermarket cranks work?
Old 03-28-2009, 04:33 PM
99LS6SS's Avatar
And what heads could you bolt onto one of these? Could you bolt LS3 or LS7 heads onto a LQ9?
Old 03-28-2009, 04:38 PM
NemeSS's Avatar
lq9 24x as well. ive come across a few lq9 and none had 58x.
all 24x. there may be some 06+ that may have 58x.
Old 03-28-2009, 04:41 PM
NemeSS's Avatar
negative on ls7, ls3/l92 will work
Old 03-28-2009, 04:47 PM
99LS6SS's Avatar
Why won't the LS7's work? Sorry these might seem like dumb questions but I've never delt with an LS7
Old 03-28-2009, 05:15 PM
DevilDog99TA's Avatar
The LS7 changed the degree of the heads as compared with the other LS motors. I dont remember the exact angle but that is why.
Old 03-28-2009, 07:08 PM
Soul TKR's Avatar
no contest... I LOVE the 6.0, there's no reason not to lol
the bigger engine helps raise that TQ curve throughout more of the rpm range...
My mods are in my sig and on my sig pic... I like it MUCH better... really powerful!
Old 11-10-2010, 10:07 PM
Brandon331's Avatar
I am about to put a lq4 in my car is there a differnce in the trans or will the t56 bolt up?
Old 01-28-2012, 06:50 PM
BowtieHustleLA's Avatar
Can Both Of The Bottom Ends Handle The Same Amount Of Power?
Quick Reply: LQ9 or LQ4
