tranny coolers?
tranny coolers?
ive got a 99Z28 new motor, tranny, 3200 stall all less then 7k miles tuned but when i drive for extensive periods of time or when the car gets hot it doesn't shift from 2nd to 3rd but it will do it when the car is cold all day long. i dont have a tranny cooler, will that solve this problem?? thanks
Moderator
I would begin with monitoring the trans fluid temp
(scan tool, you can scan with borrowed gear even
if not licensed) just so you know what's what.
Some trans control stuff (like force motor current)
varies with temperature and if there're latent trans
problems, might end up on the wrong side of the
needed shift pressure or something. Especially if
they were messed around somehow. Or maybe
there's an internal leak, bad seal or something,
and the job gets done when the fluid viscosity is
high (cold) but it loses too much pressure at the
business end when it thins out.
If you could get the tuner to compare all of the
trans, temperature-related tables to stock and
see if any changed, that'd be a sanity check too.
