LS6 Intake Question
Old 03-27-2009, 12:19 PM
dwhiteZ28's Avatar
Default LS6 Intake Question
I'm considering purchasing an LS6 intake from a C5 Z06. Based on my searches, it appears this intake is fully interchangeable with the F-bodies even though I have cable throttle control while the Z06 is electronic. Will the throttle cable bracket bolt right up? Thanks.
Old 03-27-2009, 02:36 PM
bczee's Avatar
Yes.. I have a LS6 intake on my 99 LS1.. the LS1 and LS6 intakes should have the same 78mm and bolt pattern for the Throttle Body.
Old 03-27-2009, 04:04 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Just reuse your bracket and everything will swap right over
Old 03-27-2009, 06:22 PM
dwhiteZ28's Avatar
Great..thanks guys.
Old 03-27-2009, 06:26 PM
allforspeed's Avatar
if you want to keep your EGR though you will need to be sure the intake you are buying has EGR i believe.
Old 03-27-2009, 08:44 PM
jrob56's Avatar
No LS6 intake has a hole for EGR except those modified by SLP or I suppose you could do it yourself, but who hasnt ditched EGR already anyway?
Old 03-27-2009, 11:25 PM
Blk_Ws6's Avatar
Loll^^^^^^^
