Fueling & Injection - duty cycle??
cals400ex
03-27-2009, 01:50 PM
i recently had my car tuned with HP tuners. i have a fair share of mods for stock injectors. according to the wideband it is getting enough fuel. however, where should my duty cycle be at? i read that some peoples are 100 and others are 80 or so. i don't know what i am striving for? i have heard that the cars often make more power with higher duty cycles and i know they can be easier to tune if the injectors are not too big. any input would be great.
405HP_Z06
03-27-2009, 02:16 PM
Rule of thumb is not to exceed 80%. If your consistently over this threshold you need to look at larger injectors.
cals400ex
03-27-2009, 05:01 PM
what is the reason for this?
Magic Man
03-27-2009, 05:38 PM
They work most accuratly between 20 to 85%.
ZL1Killa
03-29-2009, 10:13 AM
everything has an operating range.
www.rceng.com and click their technical link
FICINJECTORS
03-29-2009, 10:53 AM
above 85% the injector is spraying with the valve closed to keep up. 100% is static, meaning the injector is no longer pulsing, but staying open all the time.
cals400ex
03-29-2009, 01:39 PM
what is the disadvantage of the valve being closed or if it is no longer pulsing?
FICINJECTORS
03-29-2009, 02:15 PM
you are spraying fuel onto the back of the valve where it puddles, if its no longer pulsing then you have reached the max for that injector, and a lean condition is imminent.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
