what series
Old 03-27-2009, 03:10 PM
snk-huntr's Avatar
Default what series
anyone know what series gears I need 4 a 94 a4 ta ,has 273,s now and Im going with 342,s jegs brand , any opinions welcome,thanks..
Old 03-27-2009, 03:13 PM
RamAir95TA's Avatar
You'll either need to step up to a 3-series carrier, or buy gears designed for a 2-series carrier.
Old 03-27-2009, 03:23 PM
snk-huntr's Avatar
so I need 2 series right? and also is it 7.5?
Old 03-27-2009, 03:27 PM
snk-huntr's Avatar
wouldnt have a part number for a 342 gear that would work do you ?
Old 03-27-2009, 03:34 PM
skanitz1's Avatar
This is what I found for the jegs brand ones on their website, should be what you want.
p/n: 555-60008
GM 7.5" Ring & Pinion
3.42 Ratio
41-12 Teeth
For 3.08 Ratio and Numerically-Lower Carriers
Old 03-27-2009, 03:35 PM
RamAir95TA's Avatar
7.5" and 7.625" gears are the same.
What skanitz1 listed will work. Why don't you step up to 3.73s?
Old 03-27-2009, 03:49 PM
snk-huntr's Avatar
I may go 373 not sure,will this gear also work, richmond 836-49-0007-1 ?
Old 03-27-2009, 04:06 PM
snk-huntr's Avatar
p/n: 555-60008
3.42 Ratio
41-12 Teeth
what about this one if I go 373,s jegs,555-60010
Old 03-27-2009, 04:07 PM
dlk1950's Avatar
If your car will see strip time go with 3.73s..Richmond gears seem to have some whine, at least mine do.
Old 03-27-2009, 04:32 PM
skanitz1's Avatar
looks like either of those should do the job.
Quick Reply: what series
